using a 02housing EXT gated turbo in manifold Mounted EXT mode?
Lordpaxin
1,890
15
Apr 21, 2003
Jackson County, West Virginia
I am curious,
Is there any Ill effects on a turbo with a wastegate passage wide open, just blocked by a plate welded over the wastegate hole on the 02 housing side ?
With the O2 housing gasket getting the full pressure of the pre-turbine exhaust I'd be sure that both the O2housing and turbine outlet flanges were true and that a good O2 gasket was used. Other than that, as long as the O2 entrance was completely sealed, I see no problems :dsm:
ok, i was just curious about the open passage, if it would create backpressure and disrupt flow.
