Different AFR in Different Gears
wira4
Oct 4, 2002
k, Asia
With the Haltech, I am able to get to the right AFR at WOT at certain rpm and boost in 1st and 2nd gears. However, as I am in the third gear, I will get a richer AFR at the same rpm and boost . If I were to lean out the fuel map at this particular rpm and boost, I will surely end up with leaner AFR in 1st and 2nd gears but the right AFR for third.
My question is will it be okay to have ,say, a 12.9 AFR in first and second gears and ,say, 12.5 in third gear? First and second gears go by very quickly as in many cars and I wonder if that split second lean mixture would kill the engine.
Thanks
That is strange.
Usually, you will be leaner in the higher gears, due to more load.
You probably should look into why this is hapening.
...Kyle T.
  • For sale 4G63 FIC 1200cc Injectors
    FIC 1200cc Injectors $350 + shipping and paypal fees* injectors were cleaned 6/23/26You must...
  • For sale LC2
    Used LC2
    • Anthony Hornback
  • For sale 1g Flip up covers
    Pair of black flip up covers
    • Anthony Hornback
  • For sale 1g Flip up headlight
    One red flip up headlight and the black trim piece for the other
    • Anthony Hornback
  • For sale 2g sunroof shade cover
    I have 5 sets of these. They are freshly re upholstered. The material I used was black suede. I...
    • Jose gonzalez
