afc not working correctly
white20gfwd
111
Nov 28, 2002
ilion , New York
i just got my car running and my afc works but it dosnt. i put the display on throttle,rpm, and karman. well the display works but once u hit a higher rpm or throttle the numbers dont go down to normal. for example if i reved it to 2500 it would stay at 2500 untill i hit 2501 and so on. i dont get it.
You have it set to display peak values right now. While it is displaying that, hit one of the arrow keys, I cant remember off the top of my head which one it is(been a while since I owned an AFC), but it will switch it back from displaying peak values to displaying current values. It should explain this in your instruction manual.
Brad
