How to install.....A/F gauge...HKS turbo timer...SAFC?
TalonTsiAWD94
119
Apr 24, 2002
hi I'm kinda new to the whole tunnin DSM....well I'm only 16 but have a love for "hookin up" my 94 talon....so i was wondering if ne1 knows of a website or sothing that would tell me how i could install a colbalt A/F mix gauge.... a HKS turbo timer type 1....and a apex SAFC.....thanx for all the help .......Jay
turbo timer:
get the harness its a plug and play event. if the hks has a e-brake wire and rpm signal wire those are the only two wires to tap. make sure you ground to the frame of the car.
a/f gauge:
Very simple also, ground to the frame like above. Maybe in the same spot. you can either tap the o2 signal wire at the ECU, or under the passenger kick panel is a wire with a clear connector. Its much easier to tap it at the ECU since you will have the ECU harness exposed for the turbo timer and safc install.
SAFC:
not much to add to this one
http://hawaii.dsm.org/howto/afcinstall.html
