Reseting ECU with new AFPR
garrek11
201
Apr 4, 2009
Spokane, Washington
alright so when i was reading some of the other threads it said to reset the ECU when i was done installing my AFPR and i did which the car ran great had a lot more power. however after like a day driving it it went back to having not as much power. Why?
(Mods) 255 fuel pump, BOV, and AFPR.
someone told me it might be the fuel trims? what are those and where are they?
Is your bov recirculated? Fuel trims have to do with compensating for different qualities of gas and boost leaks. If the bov isn't recirculated, then you get rich conditions, and the fuel trims are adjusted to try to bring it back to where it's supposed to be. Unless your bov had a massive leak, put the stock one back on, it's one of the best out there. That extra power you felt was from your car running right in boost, instead of trying to fix off-boost problems.
