14b turbo
Vinnie
273
Aug 29, 2002
Toronto,
I just installed a 14b turbo in my 96 talon AWD.
When I had the T-25 my EGT readings by the end of 3rd gear were around the 1250-1300F.
Now with the 14b, by the end of 3rd gear I'm reading 1600F, I have to let go of the throtle and call it off.
Anyone know why this is happening???
I'm still running the stock injectors with the same fuel pump as I was using with the T-25 (walbro 255)
Thanx guys,
It's happening becasue the 14b has more power in the upper rpms than the T-25 causing you to run leaner.
You will have to increase fuel in the upper rpms (via a fuel computer) or lower the boost.
Yes you can add a little bit but not much w/o upgrading the injectors.
I'm running 16.5psi do you think that could make a difference???
I'm going to lower my boost and see what happens.
First off, you have a MAS, the MAS is perfectly capable of compensating for the size difference between a 14B and T25. No AFC should be needed. Secondly, EGT gauges are stupid. My friend and I tested about 10 probes in boiling water and found that none of them were right and they were all off by different percentages. Most gauges are off by 3% as it is, we found that eight of ten probes was off by at least 5%. Totally usesless. 8% at 1500 degrees is 120 degrees. Also their abilities to accurately sense temperature decay over time. Pretty crappy.
You need to measure knock.
    • 92AWDHX40
    • eclipsemf
