Slow old poop
- 707
- 7
- Jul 24, 2005
Cedar Rapids,
Iowa
Iowa Speedway Report
A good day, a bad day, an awesome car, a great crew and we broke it again.
I was in TTR, because I've never gotten a dyno sheet on the DSM, so they stuck me into TTR (I ran last year in TTB) until I get one. Fortunately, I was the only car in TTR, so I got two automatic wins, which looks good on the resume.
The NASA event at Iowa Speedway was held in absolutely gorgeous Spring weather, on a brand spanking new oval/infield. The course is a 7/8-mile oval plus an infield. We were on the oval through two and a half turns.
Here's a video, taken at the Grand Am race the week before:
http://www.youtube.com/watch?v=_CD2_rKcXVQ
We set the Eclipse up for turning left: max neg camber on the right front, 0 camber on the left front, and raised the right rear an inch. It turned left just fine, but plowed through the only two right turns.
SATURDAY
The first warmup session on Saturday was interesting, because no one had ever run there before, so we all danced around, trying to find the line. Fortunately, being an old rally driver, I pick up a new track fairly fast, so I managed to cut a respectable :55 (about an 84 mph average speed), running on my 235/17 Toyo Prox RA-1 beat up, worn out practice tires. Not too bad, considering that the Grand-Am Acura in the video above turned a :53 the week before.
I got flagged down at the end of the session for oil smoke. It seems that I was blowing smoke at the same point on the banking every lap. Mike, the crew chief, diagnosed it that the oil in the pan was sloshing over to the right and blocking the turbo return line, which forced oil out the turbo oil line fitting. He crawled under there and tightened it all up. The smoke went away.
We put on 245-40/17 Hoosiers for the next session, and expected to really turn some good times. Alas, I only turned a :54. One second! That's all I get for Hoosiers? BFD.
In the third session, I cut a half second off that time, and found myself the third fastest car of the day ahead of some intense cars—Z06es, A Mallet Z06, Cobra SVTs and the usual gaggle of cars—about 48 or so in all the TT classes.
The Eclipse was one of the few cars that could run the high groove. Most everybody would try the high-low-high line (go high, cut down low to the apron, and drift back up high, as on the video), or stay in the low or middle grooves, but the Eclipse just stuck in there, so I could blow by four or five cars at a time on the oval.
http://www.ink3s.org/pub/mirai_strife/Rich/Rich4.jpg
http://www.ink3s.org/pub/mirai_strife/Rich/Rich.jpg
Some of the badass high horsepower cars would catch me up in the infield, and I'd enter the oval with a Z06 or an SVT right on my bumper, but they couldn't stick on the banking, so I'd pull away from them. The infield was a waste—unimaginative, no place for an AWD car to shine, and dreary.
http://www.ink3s.org/pub/mirai_strife/Rich/Rich2.jpg
The track could be summed up as: 30 seconds of sheer terror on the banking, followed by 30 seconds of boredom in the infield. I say terror, because running the high groove can be dangerous.
First, there be marbles up there, and the car can get squirrely when it gets into the dirt and dust. Second, the wall likes to eat cars. After a tank-slapper, it was explained to me that running close to the wall tends to compress the air between the car and wall, takes away any aerodynamics you might have, and the wall rejects you. At about 100 mph, my tail kicked out and I did a wild left-right-left-right "tank slapper" down the track. I thought it was all over, and the Eclipse was going to wind up in a blue ball of metal, but I managed to straighten everything out. WHEW!!!!
After the tank-slapper, I stayed one lane away from the wall. But now I found myself lifting a little to keep the car down, whereas before I was flat all the way around. Nevertheless, I was still coming off the banking at 125 mph. Bang the brakes to get the nose down, turn in, nail the gas and accelerate up to the next turn at about 100 (not exactly the same way the Grand Am car was doing it). Alas, that was the only good turn in the infield. After that, it was a hairpin left, left, right, right, and left onto the oval. So, the car comes down from 125 off the banking to 100 into the infield to a 25-mph hairpin. Lift-brake-turn-mash gas-brake-turn into the hairpin. It happened about as fast as you can read that.
I am pleased to report that the new fat Stoptechs held up to the abuse, although we did wear down the pads considerably. 125 to 25 once every minute will do that.
Still not happy with the performance of the Hoosiers, I consulted with Phil's Tires, and Phil said I should be running 40 psi HOT, not cold. Omigawd! We had inflated the Hoosiers to 40 psi COLD in the morning. They were probably running 50 psi when we came off the track, which was way too hot. No wonder they weren't up to snuff. With one session to go, we dropped the tire pressures to 38 cold, and tried again. This time, we checked pressures immediately after, and found them at 45-47 psi. We bled all four tires down to 40 psi hot and packed it in until Sunday.
SUNDAY
Checked the tire pressures first thing in the morning, and they were 31 psi COLD. What to do? We decided to leave them there, figuring they would heat up to 40 psi after a few laps. It takes about three laps to get heat into them (Don't forget, these are :54 laps, and we'd get 19-20 laps a session.) I took Jon, my neighbor/crew along for the first session, and we cruised to a :55. Not bad, seeing as how I had an extra 150 lb riding along. Some minor pressure adjustments after the end of the session got them all at 40 psi hot, and we were ready to go again.
Next session, Jon rode along again, even though he said the banking terrified him. He said although he was strapped in as tight as he could with the five-point harness, in the banking the g-load had him riding on his right butt cheek. He could hear the Hoosiers HOWLING out the right window and thought we were a smidge away from losing it the whole way around. "Hoosiers don't howl unless they are ready to let go," he opined.
He also discovered that the data logger spiked at a 100 knock count every lap on the banking momentarily, at the same time I lost the tach. We figured later that we must have a loose connection in the ECU wiring that was affected by the high g-load.
The Hoosiers were really hooked up, now that we had them at the proper pressure, and we were really flying until we blew an oil filter, blowing a cloud of oil out the hood vent and all over the track. It blew up on the banking, so I had to come down through six lanes of race cars, brake for Turn 1, get off the racing line, and look for a place to pull off. Alas, there was no good place to pull off, but since I still had oil pressure, I drove it back to the pits,
http://www.ink3s.org/pub/mirai_strife/Rich/Rich3.jpg
shut if off when oil pressure dropped to zero, and coasted in. I probably drove too far.
We ("we" means my crew) cleaned it all up, refilled it, drove it around for a while, did some 2nd and 3rd gear pulls out on the highway, and decided that it might be OK. It wasn't. Next session, it made horrible engine noises after a few laps. I thought it was the exhaust, because it sounded like the downpipe fell off, but it wasn't. The alternator belt was shredded, but it wasn't the alternator. We pulled the cam cover and the timing belt cover, but couldn't find anything wrong. We think maybe a rod bearing. We'll pull the pan Tuesday night and see.
*sigh* Sunday was not a good day.
Observations:
o The Eclipse is one strong lil mutha, capable of running with nearly anything out there. If we had some aero (front splitter and a wing), I could have run the oval flat all the way around and maybe beat 'em all. Needs a splitter at least, and maybe a rear wing.
o We have to do something about the oil filter problem. Jon, who was watching the gauges, said I was pulling 110 lb oil pressure at 20 psi boost. This is the 4th oil filter I've blown the seal out of. A remote mount?
o Brent's scheme to bolt the transmission to the front engine mount
http://www.dsmtuners.com/forums/showthread.php?t=258925
seems to have worked. However, toward the end of each session, it gets harder to downshift to third and upshift to fourth. A tranny cooler perhaps?
o Next time I see a cloud of oil smoke come out of the engine compartment, l'l stop and get off the track immediately.
o Gotta get a video camera in the car.
The photos here were taken by Jessica, a 3000GT driver, neighbor, and proprietor of Black Flag Photography. She sent me a few quick shots so I could post them here tonight. Here's hoping she'll download more photos tomorrow.
Thanks to my crew: Brent, Jon, Little Dan and Mike. I couldn't do it wihout them. I'd come off the track soaked in sweat and plumb wore out, and they would take care of the car every time.
SATURDAY
SUNDAY
Observations:
If you look up in the right corner of the 2nd to last pic, you can see my 98 GS dd parked there.
: Heres a vid of Rich running. I had to minimize it and cut down the frame rate a bit but I got the "boring" part as he calls it - the infield.
