GSTeclipse
- 339
- 0
- May 28, 2002
Winston - Salem,
North Carolina
I am plaining on seeing how far I can take a stock Bottom end 7 bolt and I saw that the recorded is 554HP ? If anyone has any info on this guy's set up and what it took for him to get 554hp please post it for me ! Also was his a 1g or 2g 7 bolt
The guy on 1320 Video did 450+ at the wheels and I want to try it my self to see how far I can push my stock 7 bolt .
My 7 bolt has compression of 180 accross and has 118K on it
So far what all I am doing to the Bottom end is Removing the BS , and adding ARP rod bolt's to try and hold it together and that is all I am doing to the bottom end.
To the head I will be leaving a 7 bolt head on and doing a light/mild port and polish job , crower valve springs and retainers , FP 2's or 2x's , 1g intake manifold or magnus have yet to decide , 1g TB , ARP head studs ...
Tunning will be done by DSM link
Turbo will be a 60-1 or bigger
Fuel will be 880cc injectors , Supra Fuel pump or twin Walboro's (which should I do?)
Aeromotive FPR , all SS lines .
Drivetrain is ACT 2900 , ACT flywheel
so please throw info my way , if you see something wrong do not be affraid to hurt my feeling's
Thanks
Thanks
. . . The only true way to determine the limit of your engine internals is to pop it. It really discusts me to see guys willing to destroy a perfectly sound and efficiently operating machine for the sake of pushing it to the ragged edge to 'see how far I can take a stock Bottem end'... I don't know you, but I would assume that you would probably be satisfied with a reliable and "streetable" 450whp. This is entirely possible. So . . .
! Look at SBRs 3500 and 400 clutch kits. Cheaper than the ACT 2600-2900 and perform about the same, with less pedal pressure.
It would be nice to steal his thunder a little bit, but you won't see my car cutting 10.7s.
