mbc blows air from wee li'l hole?
Korndogg
471
Jun 21, 2003
randolph, Vermont
hey all
just decided to do a boost leak test, and was suprized when my mbc started blowing air in my face and whistling.. it only does it after a certain PSI (not sure what psi though).. why the hell is this? suppose i should buy a new one, but the hole is there very intentionally.. the intake system deffinitely holds pressure after the mbc whistles for a second, but it obviously doesn't hold boost above the psi that it starts leaking at.
is the psi that it leaks at maybe whatever i have the mbc set to?
thanks for the info guys, i understand now
suprized me to catch that breeze in the face though, haha.. happened to have my face just above it trying to put pressure in the device i made and bolted to the turbo..
if any of you are still reading.. should the intake piping running to the intake mani feel firm when under pressure like this? (like, while pressurized at 16 psi or so?
thanks
if your talking about IC pipes then yes, it shouyld feel pressurized. when there is no air, you should be able to squeeze the pipe (assuming they are stock rubber) and when it is pressurized, you shouldn't be able to squeeze. hope this makes sense.
weird
that's what i figured, but i could squeeze mine easily
'spose i'll have to look into that
dave99gst said:
yeap - thats why they call em bleeder valves :)
Well, a bleeder vents-off the pressure to the wastegate to regulate how far it opens, while an MBC more regulates when the pressure is allowed to go to the wastegate. They need the vent hole to let the wastegate close again.
It's the man behind the curtain, and ignore him.
