Ice03
- 43
- Jan 7, 2003
Well I jus bouht a 90 gsx thinkin it jus had a bad ecu but after I replaced it I found to my surprise that I also had bent valves. So after ordering a p&p head I installed bronze valve guides, stock valves and springs but upgraded retainers. well after I had that done I threw it on and went about breaking in the head not going past 3K rpm the whole time for 200 miles. Well one day during my lunch break at work I was going to get somethin to eat with my friends and i'm driving normally and as I went to shift to fourth it made sort of a messed up grinding noise coming from the engin but I thought it was the tranny at first so I put it back in gear and let the clutch out slowly and it made that horrible sound again then I finally looked down at my tach and the rpm's had fallen to zero and all my lights were on so I thought it jus died because a leak somewhere and tried to start it again but I jus got that nasty sound once again so I let it coast till I found a place to pull over. I opened the hood and everything looked fine so I called the shop up and had it towed. At first I thought it had skipped a tooth but that wasn't it. Then my mechanic observed the engine while I tried to started once again and it didn't look good at all. He told me that it didn't skip a tooth because the cams wouldn't even move when I tried to turn it over, but why would this happen if I jus had the complete head redone? Has anyone had this happen to them? and what was it? Is it pretty bad and will I have to redo all my work once again? Damn I'm gettin tired of these cars breaking down all the time.
I need something more reliable. any info would be greatly appreciated thanks
