heavy/mushy clutch, wont go into R,1st,3rd,5th gears
sting0004
429
Oct 29, 2002
Buckscounty, Pennsylvania
My clutch feels very stiff when the car is just turned on. I pump it alot...a hundred times or so and the feeling doesnt go away. The car wont engage 1st or 5th at all. It will grind if I try to put it into 3rd or reverse. It goes into 2nd and 4th easier but not like it did before the problem. Another problem, maybe unrelated, i dont know, is that the car (probably tranny) will whine when im light on the gas. The whine will go away if I hit the gas hard or start to boost. Thanks for any help or suggestions on the problem. Feel free to ask anymore questions to help diagnose the problem ~ Matt
For the clutch problem I would check and replace my slave and master cylinder first. If that dosnt work its a clutch and pressure plate problem. As for your tranny whining I just had the same problem I changed the fluid it calmed it down a little. About 3 to 4 mounths later I blew my third gear my brand new tranny dosnt whine at all.:dsm: :thumb:
Check for fluid coming out of the master (under the dash) or the slave (front of the tranny). If one is leaking, replace it.
Also, bleed the hydraulics.
