lugones
- 0
- Jun 1, 2010
Miami,
Florida
I installed a new xtd stage 4 clutch and pressure plate with new release bearing recently but it seems this wasnt my problem i made the car work by bleeding the whole clutch system and it was going into gears but not 2 easy then after a few days without moving the car i had the same problem the car wouldnt go into gears so i try bleeding it again and nothing the car still wont go into any gear at all now there is something i didnt do that i think can be causing me this strugle i was supose to add grease to the part where the release bearing slides and all those parts there as well as the release bearing and the fork but i didnt can this be whats causing the car not to go into any gears? and i already bleeded it all with a new master and slave cylinder and my pedal its with good pressure. i really need help with this is driving me crazy not to be able to drive my car because of not being able to go into gears so i would really paresiate if anyone can help me out find out whats the problem by the way my car is a 98 eclipse spyder with the 4g64 engine on it wish is basicly the 4g63 without the dohc
