idle problem
SlammedSliver99
214
Mar 9, 2003
Maryland, Maryland
need some help my car is idleing weired its sitting around 1500 at idle then some times it drops to around 200 and it sounds like its going to stall on me then when i gas it it jerks and sputters a little bit put when driving it seems to be ok put ocasionally it sputter when lightly putting on the gas so if any one could help me out that would be great thanks
I need more info to really give you a better guess, but I can tell you what was wrong with my car when it idled bad.
First thing was a huge air leak out of the turbo when I replaced stock IC pipes with Dejon Tool ones. That also broke my spark plugs because it was running so rich. Are you plugs ok looking or are they black or white?
Second thing I don't know WTF's wrong with my car but I'm looking into the electrical system for the spark cause its misfiring now.
Could use a little more info like if its only when idling and if your car runs fine if when you're driving around on the freeway.
BlackViper
Yeah, are you venting? Your profile is at about the same level "useless" is...
