stjoetalon
- 67
- Jun 3, 2002
St Joe,
Missouri
I have a problem with a high idle. When the car is cold, it will idle fine. But once the car warms up, it idles between 2k and 3k. The manual says to ground the blue plug on the firewall, and then adjust the idle, shut the car off, un ground it, start it back up and let it idle for 10 minutes. So I did that, and it didnt work.
The car has sat for 2+ years, and I never had an Idle problem before. What could cause this? Would a vac. leak cause this? I cant find any, but I will look harder if it is possably the cause.
I have a 2g turbo
I have a 2g turbo
