JuiceGsTurbo024
- 167
- Mar 3, 2003
209,
California
Hey everyone i am almost done with my engine swap! I have a 1990 Eagle Talon Tsi and my timing belt went bad and the teeth broke off where the crank turns the timing belt! so i take out the motor and drop in the extra motor that came with the car got a good deal. Its from a 1992! I switched everything over but the oil pump, so i go to connect the oil cooler and the Oil cooler bolts fit! but When I connect the first Oil Cooler Bolt the other one cant connect its to big and cant get on! So i am thinking of just running this SS Oil Cooler! So what should i do? can this work on this motor i see it says its for a 90 only! so i amnot sure if it will work? also i was reading something that 91 up had a oil water cooler that is different! i also need to connect the line that comes of the water pump to the cooler right? i will take pics of that tommorow! and post them! show you what i mean wait i have some right now! Here are the pics! you can tell which one is the 90 motor and the other one is a 92! i checked vin and its a 92~ well thanks for your time and reading the post! and again thanks DsmTuners and all of our community!
Juice
PS
Just got my 2nd Talon Tsi! real nice original owner!
Juice
PS
