tsunari
- 1,031
- 35
- Feb 12, 2003
Jessup,
Maryland
Yeah pretty ugly sight . . . here's the deal:
Oil pressures at idle have started to drop and are now down around 6-7 psi @1k RPMs when fully warm. Motor has no BS, no squirters, JE Pistons, stock oil bypass valve . . .
Pull the timing belt off and sure enough, the oil pump shaft has a TON of axial play in it (it's disgusting) and oil is actually leaking past the shaft & oil seal. So the oil pump is toast . . . I decide to check the cams and some of the journals have started to gaul. The ones at the very end of the oil galley (closest to the cam gears) look the worst.
While in the head, I found glass beads / sand just chilling at the bottom of the head and also on some of the valve retainers. I'm guessing this is due to the assembler not cleaning the head out completely after it was machined.
Getting this work fixed under 'warranty' is not an option -- (another long story) so what should I do now? Pull the motor and completely redo all bearings, rings, etc . . . pull the head, flush it out and check main bearings/rod bearings for damage and hope the head isn't trashed?
What are your guys' thoughts?
, they are supposed to clean out all the glass beads after they blast it. sorry buddy
