sepulchral
- 61
- 2
- Dec 9, 2005
midlo,
Virginia
Hey i rebuilt my friends motor, its a 7bolt 4g63 with pistons and rings and headgasket arp headstuds and a milled head. The car burns oil pretty bad, and after running for a while cylinder number 4 (furthest from the timing belt) has oil smoke rising from the cylinder when i remove the spark plug. I compression tested the motor and numbers were as follows: 180,165,165,165 then i put oil in each cylinder and it changed to 190, 170,170,170.. don't ask why i put oil in the cylinders i just wanted to see if the numbers changed much..
Anyways when i had the head milled the cams were removed and i just put them back on and torqued the cam cap bolts down.. what could be causing that cylinder to have such high compression and to leak oil?.. I did not bleed lifters and i don't really know how to (so please tell me how).. car ran fine before i rebuilt it (it just had crankwalk out the ass and stripped bearings)
