10 MM not 13mm(Haynes Manual)-Retorqued Head
Mitsu RacerX
2,821
4
Feb 25, 2006
On the beach, Mississippi
Does anyone know where I could get the 13mm allen head socket to remove the head bolts. I have went everywhere even the dealership. Napa said they could not get it. All info is helpful..:confused:
I would like to thank Vintage for the info. My book says 13mm when actually its a 10mm Allen head socket. Does anybody else know where the Haynes manual might be wrong. :thumb:
They say "installation is the reverse of removal".....a lot....
And they never tell me what to do with the leftover bolts...:cry:
And...if you're going to work on dsm's ....get the lifetime warranty on the socket...you'll probably wear out several...one cylinder head at a time...:D
I retorqued the head back down and drove it around and the temp never got up past 1/2 way. When I got back to the house I poped my hood and there was NO steam being pushed out my rad cap.(it was before I retorqued the head). I opened the rad cap. a lil steam and water came out but after I took off the cap all you could here was the water in thre block. I'm running with no t-stat. I also only had water in it no coolant. do you guys think it ok. I'm going to put coolant in it. (Oh yeah when driving around I outran a Lincoln LS light to light.)
