Weird metallic ringing sound at idle, goes away w/ throttle blip
Woodsy0
177
2
Apr 1, 2004
Lexington, Massachusetts
When I'm at idle, my car makes this really odd high-pitched metallic sounding ring. If I blip the throttle, the sound goes away, but when the RPMs come back down, the sound comes back. I opened up the hood and manually manipulated the TB to try to pinpoint the sound, it seems as if it's coming from the fusebox/airbox/upper intercooler piping area...I have DejonTool intake and upper IC pipes, which may be a factor in the problem, but really I have no idea how to pinpoint and fix the problem, and it's getting really annoying idling around town with a weird ring coming from my car. Any input would be appreciated.
Thanks,
Scott
Is there anything touching the metal piping? A cable or wiring harness tapping the pipes may make a musical kind of tone as it bounces against the tubing.
I've had a couple of funky noises from stuff moving around at idle that went away with a few rpm's.
My cars kind of a pile..and idles a little rough at times..so I've heard a few extra sounds that are but a sweet harmony measured against the lifter tick, and exhaust leaks etc..that make up the usual underhood soundtrack....
*Cue Lifters*
*and the exhaust leaks......... NOW*
*Fade in the belt squeals... yes..... nice*
Haha, I actually just made a boost leak tester a couple weeks ago, never got around to actually testing for leaks...That's probably what it is, I'll let you know after I test.
