Batmobile
- 431
- 1
- Feb 23, 2004
Olathe,
Kansas
Okay I need to replace the crusher washers on the oil feed line to the turbo, its leaking. But i can't find them anywhere? Where should I look or how can I fix the leak?
Defiant said:A real hardware store or auto parts should have a box full of assorted sizes.
Those may work, but be aware that crush washers are annealed, while washers are hardened. You want the annealed (softened) washers next time. Ring terminals are suitably soft.harjms said:well thanks for the replys but this is the way i had to end of doing it. I went to my local ace hardware and bought 4 copper flat washers.
flinguist said:If you re-use them, sometimes they will leak,
