Need some help with tranny diagnosis *WISEMAN* help mee
yanks12524
Nov 17, 2002
New York
I was driving the other night beating my car all night with some friends and on the way home i dropped it into third and went WOT after a few seconds of being in third i heard a loud pop and then the car was locked in third gear i rolled to a stop. Ok soo the thing is the car is stuck in third but i can start the car put the clutch all the way up nothing grabs but u hear a scrapping sound also the car rolls when u push it..
Its an 96 awd
i had an act2600 put in feb also fidanza flywheel
does anybody have any ideas if you need a better explanation i will try just please post any ideas u might have
thanks kyle
Its an 96 awd
thanks kyle
act 2600 and lightweight flywheels (aka 9 pound fidanza) are not a good combo, Possibly your flywheel crumbled up and turned into soup?
also your flywheel might of been stepped incorrectly...
Before you go suspecting your clutch/flywheel (I run the same combination with no problems), drain your transmission fluid and see if there is any metal in it.
Easy check, and it will tell you if its the transmission or not.
