LVEVO3
- Sep 9, 2008
Boise,
Idaho
hey guys. i'm having quite the issue. i have a 94 mirage with a 4g63t swap. ive been fighting with an ecu issue since i did the swap. i got the capacitors changed out by a guy in bremerton and its been working for a while. except the check engine light has always been on and when i would try to check codes, there would be no voltage on the self diag wire. now the car doesn't run. the main relay clicks while its dying. i would like to know if i can test this ecm in someones car or if someone has a 1g ecu i can test in my car. please let me know asap. the ecm is a 90 laser 5-spd non abs. thanks!
ben
ben
