Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > Pacific Northwest DSM Forum
Pacific Northwest DSM Forum Washington, Oregon, Idaho, Alaska, etc.
Pacific Northwest Region Homepage
Reply
LinkBack Thread Tools
Old 06-17-2008, 03:37 PM   #1 (permalink)
New Member/Lurker
kiwidog's Avatar
Region: Pacific Northwest
Classifieds Rating: (0)
Reputation: kiwidog is an unknown
1G-specific Rebuilding--Looking for opinions
I put this in the newbie area but figured I'd put it here as well so all you local guys could see it and help my out with comments and suggestions pertaining to what my plans are.
So a couple months back my can went down because I spotted a huge oil puddle under my engine and found my timing belt to be covered in oil and my spark plugs smelling like oil and gas.
I've finally decided on the path I'd like to take and what parts I'd like to go with since I've decided to pull the engine and do a "budget" type rebuild. The following list is what I plan on doing and I'd like to know from everyone out there if there is anything I either forgot, don't really need or even something you may suggest I need in place of something on the list.
All comments, suggestions and questions are wanted as I'd like to do this right the first time and keep in mind I'd like to track this car as well as drag race it, so that may give you an idea as to why I've chosen the path and parts I'm going with. Also all the current parts I have are in my sig. so if you don't see something on here look there first before you post up a question or comment about forgetting a part.
EVO3 16G
EVO3 O2
2G piston upgrade
Downpipe
Exhaust
ETS street or street/strip FMIC kit
Injectors (please recommend a size as I don't know what to go with)
DSMLink
Cams (264/272 or 272/272 setup?)
Cam Gears
Sprins and retainers
Head studs
Valves (if needed)
Upgraded lifters (I still have the old annoying ticking ones)
Wideband
EGT Gauge
MAF trans for my 3" GM MAF (if needed, don't know if I still need it with DSMlink or not)
Light flywheel
New Clutch Disc (Have ACT 2900lb PP, just need a disc--recommendations on what to get)
FPR Kit
Fuel Feed line upgrade (if needed)
Also Need: New struts, springs, brakes and pads and I was going to upgrade the sways and brake lines as well since I plan on doing some track events
This is all that I can think of right now but I'm sure I'm missing something. Also while the engine is out I plan on freshining up the motor with new gaskets, bearings, water pump, oil pump, etc. -- I want to be sure everything is fresh and ready to go.
My plans are to have a 350awhp (+/-20hp) on 92 pump that I can have fun with and take the track for some lapping or drag racing when I feel like it. I am finishing up on fixing my '89 CRX that has a B18A in it for my daily driver, so my Eclipse will be for those days I just want to take it out and cruise or have some fun, it definitely will not be my daily.
Thanks for taking the time to go over this and agian all comments, questions or suggestions are welcome. Thanks guys.
Offline
Related Auctions
Sponsored Links
Old 06-17-2008, 06:09 PM   #2 (permalink)
Proven Member
fulanititoo8198's Avatar
Timeslip: 14.748 @ 94.070
Region: Tri State
Classifieds Rating: (6)
Reputation: fulanititoo8198 is an unknown
For injectors I would go 700cc and up. You have dsmlink, so controlling them won't be a problem. Some of the injectors are the same price so you might as well go with the bigger set in case you upgrade one day. I would skip the gm maf and translator setup and stick with a 2g or evo maf which will be more than enough and easier to tune. You don't need to touch your fuel lines. Street disc would work . Everything looks good though. You don't really need cam gears or 272s for that power level. Nice color 1g btw.
Offline
Old 06-17-2008, 08:15 PM   #3 (permalink)
New Member/Lurker
Reputation: ranger87 is an unknown
For sure if your pulling the motor, ditch the balance shafts. Less rotating mass = more power. Thats my 2 cents.
Offline
[posts] Reply With Quote
Old 06-17-2008, 11:37 PM   #4 (permalink)
New Member/Lurker
kiwidog's Avatar
Quote:
That was one of the things I forgot, thanks for reminding me.
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
rebuilding kraniun Newbie Forum 1 05-23-2006 04:41 PM
rebuilding. xrotaryxtsi Newbie Forum 1 02-20-2006 04:42 PM
Rebuilding LowRidHer16 Newbie Forum 1 07-26-2005 06:40 PM
rebuilding a 1.8 200Eclipse Newbie Forum 8 01-21-2004 01:51 PM
rebuilding moneybags Bolt-on Tech 1 02-19-2003 08:37 PM
Page generated in 0.13185692 seconds (75.14% PHP - 24.86% MySQL) with 10 queries
