chanley talon
- 773
- 14
- Nov 10, 2005
Spencer,
Indiana
What do you think about using a 100 psi fuel pump in a water injection kit? Is it ok to drop a fuel pump in pure methanol? I have a cooling mist injection kit already it is before the throttle body. I am wanting to inject pure methanol only at the track pre turbo using methanol i heard helps spool up a turbo on a automatic. I want to build the secondary kit using an extra fuel pump and my windshield reservoir Can this be done? Anyone try it or have any knowledge on it?
Update i went ahead and put this together as soon as i find my digital camera i will show you my finished rigged product i will be injecting straight meth into the turbo .
I am using a
100 psi fuel pump
A 240cc fuel injector from a non turbo 4g63.
My windshield reservoir tank and the wiring to it.
All vacuum lines are around 5/16 in size and a 3/8 hose and clamps.
I am using a p.v.c. for a check valve all though i don't need it really.
Pictures soon to come.
I am using a
100 psi fuel pump
