maddadgsx
Proven Member
- 50
- Feb 1, 2013
Fulton,
Missouri
The VC connects the input to the rear, not the front. AWDs that blow the center diff in the middle of a drag-race finish the run as RWD, not FWD.
Do the standard tests:
1) lift one front wheel and try to turn it with the car in gear: you shouldn't be able to ... if you can, then either the front or center diff is gone.
2) lift one rear wheel are try to turn it with the car in gear (and the parking brake off, of course): you shouldn't ... if you can, then either the rear or center is gone.
Note that these tests assume that you have not snapped an axle. If you aren't sure, check them all first.
When doing these tests, turn the wheel slowly but with some strength. There will be some slop, but if you can rotate the wheel more than 90 degrees, then the test was clearly failed. (Note to the confused: "failed" = wheel can be turned.)
If the car fails #1 but passes #2, it's the front diff.
If it fails both, it's the center.
If it passes #1 but fails #2, it's the rear.
- Jtoby
