Ilikespeed
- Jul 12, 2008
davenport,
Iowa
I have a 97 talon awd that i stuck a 6 bolt in w/ a 1g cas. How do i time it?. Its not like a 1g w/ the plug to ground next to the battery... unless i dont see it?...
Yea but you need to lock the ignition timing at 5 btc or else the timing is going to be jumping around to much to use the timing light accuretly. 95's have a tan connector on the firewall to lock the timing at 5 but 96-99 don't. That tan plug goes to pin 52 on the Ecu...Just use a logger and an adjustable timing light.
Ground pin 52 at the ECU...
Did this work for you?
I have a 6 bolt/1G CAS in my '99. I've only tried the "match timing to logged value" method but it seems that I could be off by +/- 3 degrees. That would be fantastic if grounding pin 52 works.
Ceddy, do you happen to know if the scan tool that you can borrow at Autozone, etc typically has this feature?
