Talonted Newb
- Oct 20, 2008
Littleton,
Colorado
Okay, first off HELLO!
I hope I do not get banned for what I am about to ask:
Recently I found out my 3rd plug is arcing, and I have looked over all of my spark plugs, and checked the wires with a timing light. Everything seemed normal. The guys at the shop said I need new wires, plugs, distributor, distributor cap, as well as a distributor rotor. I do not think all of that is necessary. I will try just changing out the 3rd plug, if that doesn't work, then I will do the wires. Do I really need to do ALL of that? They estimated 400 to fix everything, and I have had this car for two months. 1994 Eagle Talon 2L. FWD.
I am not very much of a gear head, I know very very little and grew up w/out a father so im just learning all of this. Also, my serpentine belt is too loose and is squealing bad and when my AC is on, my engine will bog horribly down! ANOTHER problem is my sterring wheel shakes like mad when I brake. I am sad to see all of these things start to happen...
Pics for you all coming soon. Please help me guys! Thanks alot!
Thanks alot man, this should be an easy fix and back up to some horsies in no time. I am picking up the NGK
. I would recommend you guys all for rep points but it stated I am not alowed to yet. But when I can!.....No doubt sons! Thanks again and this issue has been fixed!
