93 GSX Clutch questions
the_intimidator
41
Feb 4, 2008
Roseburg, Oregon
Well I was just under my 93 gsx bleeding the slave cyl and i pulled the clutch fork boot off and out popped a peice of metal about an inch- inch and a half long by 1/8th inch wide... im thinking its a throw out bearing or retainer peice. The questons i have are
Are the clutch kits the same between 6 bolt and 7 bolt motors and 2wd/awd?
The flywheel is stepped right?
Is there anything else i should replace while under there? I will be getting the flywheel surfaced, OEM replacement clutch kit (disc, pressure plate, TOB, etc) should the clutch fork or pivot ball be replaced? First time doing a transverse clutch job, Any tips greatly appreciated.
One last thing, does anyone happen to know what the torque split is of the diff? is it a 50/50 or 30/70 type deal or what?
Thanks again,
Eric
what i was refering to was having the stock flywheel surface.... but i wasnt sure the difference between say a 2.0 n/a fwd and a turbo awd 2.0 clutch disc and pressure plate along with TOB. so far the part numbers ive found to be the same for a 2.0 turbo be it fwd or awd for the clutch set. i just want to verify before purchasing. they have a clutch set sittin at the parts house for 139.99 for a 93 turbo 2.0 eclipse. I appreciate the help and i am just tryin to make sure of things before buying. im not TOO familiar with mitsubishi's which is why i am here to learn. Thank you again and thanks for letting me know the tq split.
Eric
alright cool... i picked up my clutch kit for 139.99 locally its a rhino pak. I also picked up 3 qts of redline 75-90W for the transmission and T-case. also picked up a haynes manual and some dot 3 synthetic brake fluid so i canflush the hyd clutch system. am i missing anything?
I really appreciate allt he help here
Eric
well trans and t-case is out, clutch pressure plate is off... flywheel is next. im done for the night... pictures will be posted on website and linked shortly... must shower first... Oo the carnage LOL
Eric
and here is the link end of page 1 shows production date and that its a 6 bolt page 2 shows pics of the carnage.... any idea's as to what may have happened?
1993 Mitsubishi Eclipse GSX - Winchester, Oregon
