3" Aluminum intake pipe for 2G MAS?
Ludachris
Founder & Zookeeper
8,843
4,672
Nov 12, 2001
Newcastle, California
I know of the Injen pipe but that is sized for the stock turbo. Is there one available for a 3" turbo inlet? I'm trying to match the rest of my intake piping. The cast FP pipe I have on there right now uses a 4-3" reducer coupler that is smashed up against my water pipe and hose. I'd rather have something that fits a little better, matches, and is lighter than a cast piece.
I guess I could just get an Injen pipe, cut it and have a 3" elbow welded on...
DEJON | Powerhouse
Click on Intake Pipes under 1st Generation - I think CIP-1gR or CIP-1gS is what you're looking for.
Edit: crap, they're not aluminum. Maybe they could custom make an aluminum one for you.
Won't a 4" silicone coupler fit over the 2g MAS? If so, I was thinking a 4"-3" coupler to a custom made 3" alum. pipe. There's a few 3" intakes on ebay but they're for 1g so I'm not sure if that would fit.
Chris,
Before you think about buying a $250 Injen pipe just to hack up you might want to check this out EXTREME PSI : Your #1 Source for In Stock Performance Parts - Extreme PSI Intake Kit : Mitsubishi Eclipse Turbo 95-99
Same style as the injen at about $100 less.
I believe Extremepsi and SLS both offer a 3" aluminum pipe as well, but neither are tapperd to fit the 2g mas.
You might also think about doing something like this if you can find a stock 2g intake pipe for cheap and then just buy the 3" pipe from SLS or Extremepsi.
By the way I believe Grant has an Injen pipe sitting in his basement he doesnt need, maybe PM him.
Dejon makes one that you need. You can get it without the recir and to fit the 2g MAS. If you use a S bend 3" aluminum pipe go to home depot and get a 4" to 3" coupler from the plumbing department.
Dejon pipes are steel, not aluminum, except for their cold air intake pipe. I've had about 4 or 5 Dejon pipes. Nice pieces, but I'm moving to all aluminum piping under the hood.
