crimsondragon
- 4,300
- 51
- Dec 17, 2006
East Brunswick,
New Jersey
Ok I changed my tranny fluid over the weekend and now it's leaking. Before it was leaking as well but not as much. When I went to check it, it's dripping a lot more now. I'm not sure what to do. I followed the Hayne's manual and torque it down to spec.
I put black RTV on both sides of the gasket. I may have skimped out on a bit of the RTV since I didn't want it getting everywhere. The pan has been damaged already by what, I do not know, but there is a nice scrape on the low end which is where it's leaking. By damage, I mean the edges of the pan were crushed to the bolts so that I had to take a screwdriver and push the pan edge off of them to access the bolts.
Is it better that I should pull it again, and try to reseal them with a tad bit more of gasket or should I look for a new pan? Or should I just wipe down the leak and apply some RTV on the seal without pulling the pan? Or maybe just tighten the bolts down slightly bit more? I'm not sure what kind of gasket it is. It's a Purolater one. My guess is it's neoprene but it may just be regular rubber so I don't know if it'll damage the gasket if I do just tighten it a bit more.
