92TsiTurboTalon
- May 4, 2008
clifton,
Virginia
Hello everyone, this is my first thread ever on a dsm forum, so ill try my best. i have some very nerv wrecking problems with my tsi talon. Its a 92 eagle talon tsi fwd with a BOV ,no cat, i think i fatter down pipe, new ngk cold plugs, and thats it i believe. The problem is it breaks up real bad at 3k like its on a limiter. it supposedly ran fine before some guys soaked the engine bay while cleaning it. after that the sputtering began. i unplugged the maf and it ran alot better. it revved up and was actually drivable. So i figured it was a bad maf. i bought a new one a plugged it up and still the same problem, i even bought a new TPS. still nothing. so i put ngk cold plugs gapped at .28 and it runs a little better, but still breaks up real bad with the maf hooked up. i doubt that its a boost leak, and i doubt the maf is bad again. maybe it needs a new idle air controller? but i think its running too rich with the maf connected. its getting good fuel to the manifold. and im sure the injectors are fine. is there anything that could have got wet or just went bad to make it sputter witth the maf connected? sometimes it will do the "rev limiter thing" then rev up a little with the maf connected but its really bad. like i said it runs ok with he maf disconnected but still breaks up on the top end. and i know that running no maf cannot be good. i dont want to spend alot of money on this thing so a gm maf is out of the question. any clues or ideas guys?
thanks ROB.
thanks ROB.
