TSi_with_psi
- 86
- Jun 4, 2005
Cleveland,
Tennessee
When im at 15psi, i can only rev up to 4100 rpms before i hit what im pretty sure is fuel cut. The car completely studderes/lurches/sounds almost like a backfire. Its really loud. Before i ported my wastegate, it would boost creep up to 17psi and then it would hit what i think is fuel cut. Now that i ported the wastegate and manifold, i dont have any boost creep issues, but it will hit fuel cut at 15psi at about 4100 rpm. My theory is that it is flowing a lot more air now because i ported it, so it hits fuel cut sooner. My question is this: Does the ECU monitor Injector Duty Cycles to decide when to trigger fuel cut, does it look at the MAF sensor signal, or could my MAF sensor be maxing out causing the "fuel cut". Im running a stock 1g maf. Thanks.
