Use of Seafoam in Gas ONLY
Allamricn
53
Jan 30, 2008
Aurora, Illinois
I bought some Seafoam to run through the fuel tank only, but I didn't know if I was going to have to change the oil or plugs after just using it in the tank...
Anyone ever just use it this method?
You shouldn't have any problems. You only need to change the oil if you put some in the oil. IF you do that change the oil after about 100 miles or so. To be honest the plugs will probably not have a problem with either method
I use a half can every winter as a fuel stabilizer too, and run the other half in the first fill up for the year. Havn't had a problem with plugs yet.
