Aftermarket cams for a N/T 4G63
Rockstar04
Nov 4, 2007
Dixon, Illinois
Will the aftermarket cams, like the HKS 280's work in the N/T version or will I need to get a 280 intake and a 272 or 264 exhaust cam?
Thanks for any help here.
And no I can't just go turbo, I am running in a class at my local racetrack that dosent allow turbos.
For a N/T engine the 272 are to harsh for the engine unless the head is built and ported, with higher compression pistons. When I was thinking of building a quick N/T dsm I decided I would put in the turbo cams, you only need the intake cam the N/T and turbo exhaust cam is the same. Never tested them though but you may want to consider turbo cams.
