blueninteytwo
- 99
- Feb 6, 2007
beacon falls,
Connecticut
well i bought this turbo (FP TD05-18G), and it had excessive shaft play, so i rebuilt that bad boy's center cartridge, checked against FP spec and it's good to go.
now i'm left staring at the Compressor housing looking like those pictures.
obviously they're from the contact made by the compressor wheel. the marks from the foreward edge of the blade are unnoticeable by running my fingernail over the housing. the other marks tho do scratch lightly the side of the housing. those i can feel with running my fingernail on it.
so what's your guys opinions, what do I do about the situation? for my situation, the turbo will be bolted up to a pretty stock setup and will be turned to about 13PSI for now, and go up progressively as 750CC injectors, FMICs and etc. are added.
i know that i'll lose some volumetric efficiency, but somehow i don't think at 13PSI it'll make much of a difference.
i've entertained the idea of a bastard 20G, but am unsure whether the machining needed to fit a 20g wheel will take care of the damage, and whether it's actually worth it or not. plus brand new FP TD06-18G's are like $700, and a much better option (apparently the 20G wheel is useless, as the TD05 hotside is just incapable of flowing enough to turn that big of a wheel efficiently)
so what do you guys think?
i dont know?
