ATLDSM96
- 127
- Nov 22, 2007
Atlanta,
Georgia
[/IMG]Attachments
6 bolts have em not 7 bolts.
What are you talking about? The 7bolt 1Gs 92.5s through 94 have them.
if you have a motor swap from a 95 you won't have one yours will be a small black piece underneath your intake cam that will looke completely different.
on a 2g with a 6 bolt short block and a 2g head will you still need the cas if you have DSMLINK?
I"m not sure if you need a 1gCAS w/ DSMLink. But every car i've seen with dsmlink has a 1g CAS on it too.
Here it's 2G DSM CAS Like 1G DSM
http://members.shaw.ca/dsm.1000q/Engineprimer/2G/cas.jpg
That is a confusing post, has already been posted, and has nothing to do with the OP because his is on the timing belt side of the motor, not on the end of the intake cam like all the other years.
