hornetracer8
- Feb 23, 2007
Belmond,
Iowa
I have been fighting this for 2 weeks now. And I have read about every thread I can find.
Please Help!!
Always RICH!!!!!!!!!
I have a 98 gst I just bought. Fresh rebuild 9:1 comp, Forged lower end. 650 injectors AFPR set at 36 PSI Base.
I have a S-AFC leaned out all the way -50% High and low.
My MAF Translator is also leaned out all the way -35%. Mode switch first 2 switches off #3 on #4 off. I also read if you set the AUX and BASE for a larger injector size it will lean out that also tried that didn't help.
My O2 voltage varies from 0.880 and .960 on my scan tool. When at idle. And if I rev up the motor the O2 does up to .990 and starts breaking up. Black smoke and plug are fouled Black.I have a new O2 sensor, No boost or vaccum leaks.
Any Ideas would help.
Thanks
Coolant sensor reads fine on the scan tool 197 to 212 when warmed up reads fine when cold also
Please Help!!
Thanks
