katz
- 54
- Jun 21, 2005
Newark,
Delaware
Hey,
I have a CEL on and it wouldn't communicate with the scanner. So I used an analog voltage meter hooked up to pins #1 and #12 (Positive on #1). I have this process repeating: 1 short voltage sweep and then 3 larger sweeps. According to Haynes manual this is Intake Air Temp. Sensor. This book also said that you test the wiring for that the same way as the actual air flow meter. I hooked up the positive lead to pin#3 on the maf housing connector and it read 12 volts. This means the wiring is good. Now they said that if the wiring is good, then you need to replace the entire maf assembly.
Can anyone verify or correct any of what I'm saying.
Thank you and sorry for the long post.
Katz
Katz
