Login
 Featured
 Products
Go Back   DSMtuners > DSM Forums > Community > Regional DSM Clubs > New England DSM Forum
New England DSM Forum Connecticut, Maine, Massachusetts, New Hampshire, Rhode Island, Vermont, etc.
New England Region Homepage
Reply
LinkBack Thread Tools
Old 06-30-2008, 07:10 PM   #1 (permalink)
Proven Member
cano86's Avatar
Region: New England
Classifieds Rating: (0)
Reputation: cano86 is an unknown
Timing issue
I aligned the camshafts and the oil pump perfectly but where does the crankshaft arrow goes directly to the bolt or to the line under the bolt I tried looking it up in the haynes book but its barely visible. Some help should be great.
Offline
Related Auctions
Sponsored Links
Old 07-01-2008, 03:49 PM   #2 (permalink)
New Member/Lurker
Region: Tri State
Reputation: willyb22 is an unknown
1G-specific Hope this helps
Hey, I found this on a site I visited, Hope it helps.It lists all the engines for the DSM's.
Here's the link- AutoZone.com | Vehicle Selection - Year
Offline
[posts] Reply With Quote
Old 07-02-2008, 01:24 PM   #3 (permalink)
New Member/Lurker
Region: New England
Reputation: boostaddict1g is more helpful than not
2g Timing Pic
This should help you.
Offline
Old 07-02-2008, 01:47 PM   #4 (permalink)
Proven Member
Reputation: SethA is pretty helpful and trustworthy
The crank sprocket mark is aligned when piston #1 is at TDC. If you have a dial indicator put something in the spark plug hole to act as a spacer (I used an extension) up to the indicator to tell when the piston up as far as possible. Some parts stores rent or lend indicators if you don't have other access to one.
Seth
Offline
Reply
Thread Tools
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Similar Threads
Thread Thread Starter Forum Replies Last Post
Timing Issue!!! Ky91Tsi Cylinder Head & Short Block 5 02-19-2007 08:14 PM
timing issue KansasDSM Newbie Forum 5 03-19-2006 02:48 PM
Timing Issue boostyGST Newbie Forum 2 11-24-2005 06:52 PM
timing issue Mits99Eclipse Problem Diagnosis 3 04-29-2004 01:57 PM
Timing issue!!! TSi90Awd Problem Diagnosis 2 01-22-2004 09:25 PM
Page generated in 0.14787793 seconds (67.75% PHP - 32.25% MySQL) with 10 queries
