jlgeclipsegsx
- 136
- Jan 4, 2011
Moorhead,
Minnesota
Hey I am in the middle of getting a different head since i bent my valves, and I have a list of things to get that will go in when I install the head. I was wondering if I am missing anything.
So far I have these items added to my cart
Cometic complete top end engine gasket set...
includes
- Valve Cover Set
- Intake Manifold Set
- Exhaust Manifold Set
- Cam Seal Set
- Water Outlet Gasket
- Intake/Exhaust Valve Stem Seal
Mitsubishi OEM organic head gasket
ARP head studs
OEM water pump
Power Enterprise timing belt
BS Elim kit
And at the moment I am looking around for a head to buy. So let me know if I am missing anything or something doesnt seem right. And also to add when i was on MAP, It said ARP head studs and a Mitsubishi oem organic head gasket dont work together and that i have to buy a mls gasket but I am not getting the head or block resurfaced.
includes
- Valve Cover Set
- Cam Seal Set
ARP head studs
OEM water pump
BS Elim kit
maybe I should post a thread or something.
every little bit helps.
