my95tsi
- 926
- Dec 6, 2002
Chicago,
Illinois
Ok have a camber kit on my car now that is the eccentric cam bolt so it only adjusts +/- 1 degree. My camber is still off by alittle over 1 degree, so i'm going to get an ingalls kit to fix the problem. But here is my concern. The upper A-arm is probably a good 1/2 inch away from touching the inside fender which is metal with black coating on it from what i see. If i get the ingalls its going to puch out that A-arm even further which would make it touch the fender well. Or is my theory pretty wrong? I don't wanna buy it unless i know its going to fit. My drivers side camber is better than the passenger side but its still off. i believe that without the camber kit it was at - 3.2 degrees so i need to use the almost the whole 3 degrees of the kit to get it into about - .8 degrees.
thanks for answering the question.....
