Krmnnghia
- 125
- Jul 30, 2003
Lansing,
Michigan
Does anyone know....Eagle dealer is quoting me 46 bucks a piece...Suspension techniques aren't even that much!!! Thanks
yes however even some people that have almost been here a while still got hosed with this rookie crap...IHeartTurbo said:Ok this isn't the first time tonight I've seen that topic title.
You guy's realize you have to type in a name for the topic where it says "Topic name goes here... read red text below" right?
I try searching "rear sway bar end link, rear swaybar end link, rear swaybar endlink" in handling and get, "Sorry - no matches. Please try some different terms. " why bother having a search fucntion for a specific subforum if I can not search it?pagosa dsm said:I replaced the front and rear sway bar links with 2 Heim joints on each side.They cost about 5.00 each. I also built a rear lower tubular control arm that connects the sway bar with Heim joints. It was not to difficult to install them on the stock lower control arms.I modded the stock arms by mounted 2 1" by 1" angle iron to the bottom of the arm.I then attached the heim joint to it.If you check out my photo gallery it might help.
hi Jeff
I used Speedwaymotors.com part # 175-0423 and 175-0113. I had to cut the threads almost in half so the heim joint would fit between the control arm and the sway bar.
I made a mistake on a part # not 175-0423 it should be175-0223
