1G Rotor Upgrade....
ILOKANO_DSM
Dec 11, 2002
ANY 1 CONSIDERED TAKING EARLIER MODEL DSM BRAKE SYSTEM(ROTORS&CALIPERS) INTO A 1G DSM? IS THIS RECOMEMDED ? :(
I am not sure what you meant but here is the low down. All front wheel drive dsms have single piston calipers. AWD dsms have single piston calipers before 93. The upgrade that people do is put the double piston calipers and rotors from the 93+ AWD dsms on what they have. Mitsubishi decided to put the brakes from a 3000gt SL on the all wheel drive Eclipses in 93. So the brakes on the nonturbo 3000gt and Stealth are a direct bolt on as well. If that is not enough, you can get Baer brakes or something.
So my question is can you get brakes from a 2g and put them on a 1g awd? or are they the same as the 93-94 brakes? Is the rotor bigger? also how much for some rotors and calipers?
Thanks
Mike
