Please Support STM Tuned
Please Support ExtremePSI
factory 2 piston big rotor upgrade 276mm-294mm
8mm more leverage goes a long way.
I still lock up my stock rear brakes like nothing else in emergency situations. The improvement from the increased rotor diameter was noticeable. I'd like even more front bias if I could. The tail wag can be pretty extreme.
So I have my rotors now and was wondering if anyone is using rotors like these for their upgrade?
They look like the would get rid of the heat very well
heres my up grade, I powdercoated gloss black and rebuilt the calipers, brand new outlander brackets are powdercoated gloss black, I have centric rotors that are zinc coated black and SS braided braked lines and EBC green pads. if anyone needs help getting this setup PM me and I can help you
Has anyone found an affordable upgrade for the rears of a GSX yet?
There is a few, just do some searching. Plenty of threads.
Either upgrade to the "Early '95" rear calipers and rotors (11.1" vented vs. 10.4" solid)
Or the Evo 8 rear brake setup directly bolts on, with a 2 piston fixed caliper and 12.0" rotor diameter.
Had this upgrade for awhile, they work great, i also upgraded to a 3G master cylinder 1-1/16" and brake booster
How does this install go? I would like to make this upgrade as well. Watched this guy’s YouTube videos on it, but he doesn’t have a break booster installed at all.
