Please Support STM Tuned
factory 2 piston big rotor upgrade 276mm-294mm
94awdcoupe
1,414
205
Nov 6, 2004
tampa, Florida
I have been aware of this for awhile now. A few years ago I came across a post on the early evo forums about a factory rotor upgrade for the evo 1-3. Early evos use same brakes as 2g AWD. 276mm (10.9") rotor and 2-piston calipers. The RVR which is the evo 3 drivetrain factory installed in EXPO body. The vehicle uses a 294mm (11.6") rotor and the same 2 piston calipers. All you need for upgrade is the larger rotors and caliper brackets. After about ten hours of research I found the details needed to get these parts here in the states.
The bracket part number is MR307282.
The rotors come from 2005-2006 Outlander. They are identical dimensions to 276mm rotor except for 294mm diameter.
1G guys could just buy rotors and calipers from salvage outlander from your local junk yards. 2G guys just need the rotors and brackets.
happy stopping..
heres a side by side of the gsx brake and the outlander brake from the 2005-2006. The outlander brake is about 8.6mm taller from the bracket hole to the top of the caliper. You can use any pad for the gsx in this to.
some pics of the install. almost clears a 15inch volk. a light 30 thousand shave off high spots of calipers and it should work. clears the 16s nice.
I can confirm that the stock 2gb 16" wheels fit over the 11.6" rotors and outlander brackets. There is about 3mm of clearance from the spoke to the caliper body. Really close...:rocks:
I'll post up my pictures later today.
I used:
brackets from a us 2005 outlander from junkyard $40
centric premium 11.6" rotors $ $90 for both
ebc greenstuff pads $50
Great upgrade, you can really feel the difference in torque! Stops much harder.
Pad will be industry #530, the same pads used on the twin-piston DSM calipers and the Outlander calipers.
The Outlander calipers are basically identical to a 2G caliper in that they are twin-piston and use a banjo bolt....the 1G twin-piston calipers are set up so the line threads directly in.
Had this upgrade for awhile, they work great, i also upgraded to a 3G master cylinder 1-1/16" and brake booster
My question: i have a 92 talon awd, stock single piston front calipers. do i need the brackets as well? if i just have to buy calipers, rotors, lines and pads then i will do this asap. so, in my situation, do i need the brackets for this to be bolt on?
yes, single piston caliper bracket is different than the dual piston caliper bracket
+1. Significant size dif between single piston brackets and 2 piston brackets.
Talking with a buddy last night as well we discovered there isn't much dif between the 2g brackets and the outlander brackets with the exception that the mounting holes are moved in slightly on the outlander bracket, pushing the bracket out a tad further to accommodate the larger rotor.
The other thing to consider is that brake lines from a 1G will not hook up to a 2g GSX or Outlander caliper. However, your 1G lines will work with N/T 3000gt/Stealth calipers.
I already have the N/T Stealth brakes on my car, so I will just be swapping in the brackets and bigger rotors.
for the record, Outlander brakes will NOT fit with 2G 5 spoke rims. Installed them today, and caliper hits the spoke. Time to bust out the grinder and shave some caliper away...
