97 TSi AWD high power Street/Drag
Carlz0r
305
11
Aug 30, 2006
Vernon, BC, Canada
Figured I may as well start a build journal seeing as I haven't updated my posts in the old system for a while. I've got a 97 TSi AWD that I've converted to a 2gb Eclipse, aiming for at least 600awhp on 94 + meth. Lets start with the specs:
Head:
CNC milled valve cover with two -10AN vent line bungs and a threaded oil cap
Ferrea competition plus valves
Manley dual valve springs and retainers
OEM rockers
Topline lifters
Crower 288/292 cams
Unorthodox cam gears
Kiggly HLA
Block:
ARP H11 Studs
BSEK
Manley Turbotuff I beams
JE Pistons
Cometic gasket set
OBX Oil pan
Gates timing kit
Oil pump
Water pump
Kiggly main girdle
Drivetrain:
ACT Streetlite Flywheel
ACT 6 puck clutch and 2600PP
Shep Stage 3 transmission
Air & Fuel system:
Shearer T4 top mount manifold
Garrett T67
2x Tial MV-S wastgates
Magnus V3 Cast Intake Manifold
Wilson 75mm Throttlebody
Tial Q BOV
Dual Walbro 255 fuel pumps
FIC 1450cc Injectors
VRSF Intercooler
JBDR Fab exhaust system and charge piping
Fuellab AFPR Kit
Fuellab -8an filter
Handling:
Blitz Technospeed Z1 wheels
Energy Suspension bushings
RM Racing Sway bars
DC Sports rear strut bar, no name front strut bar
Full front control arm kit
CTS-V front calipers, Evo X rotors
Misc:
JBDR Fab catch can and overflow tank
Fluidampr
Coil on Plug ignition with ARC-2 cdi
Prosport gauges & pod
Odyssey Battery
Sony double DIN DVD deck
Cipher Auto CPA2002 seats
Still have to buy:
Koni shocks and springs (Dennis Grant coilovers)
3000GT or Evo rear brakes
Front speakers, sub, amps
Now for some pictures from the very beginning at the end of 2010 to where it sits now. This first few posts will be a little clustered (not all the pictures are in quite the right order) but bear with me haha. The project originally started with a 97 GSX shell, and a somewhat-running 97 TSi AWD
First step was getting the motor and tranny out of the talon, as I need the tranny for the eclipse. (Originally thought I was going to build the eclipse, discovered rust that made me reconsider)
Motor in
Motor out
Delicious 7 bolt
Obligatory Person-In-The-Engine-Bay Shot
Next step was to strip down the eclipse engine bay and start work on the harnesses.
Swapped some parts over to the talon from the eclipse, and removed all the unnecessary wires from the harness. Just have to mock it up once I have the engine in to finish it up.
Then it was time for bodywork and paint:
Continued:
Dual Walbro 255 setup (one in-tank, one inline)
Started changing the nasty grey interior to black
A few painted shots
Wheels
Hood
Intake Manifold (compared to a Magnus street SMIM)
Prosport Evo gauges installed
Continued:
Some custom touches to the interior
Turbo time
Delicious built 6-bolt:
Engine bay somewhat complete (harness is almost finished, but in)
Miscellaneous final parts
The turbo, manifold, and wastegates are too large for a stock radiator! (Yes I know the turbo is upside down, just in for mockup) Gotta mount a VW Golf rad in the rad support
Balance shafts deleted, you can also see the main girdle and studs
Shiny new oil pan
EDIT: Another good shot showing wastegate clearance
Just hanging around with my brother's Supra
Should have kept it talon :ohdamn:
There's Talons everywhere up here in Canada, but you hardly ever see 2g eclipses. Plus I've wanted a 2g eclipse since my early childhood, so it was an obvious choice for me.
Latest progress:
I badly need to sand and polish the headlights
painted the car and no side skirts!
Its ok if you want to swap it to an eclipse, but do it completley... It looks like and 2gb rs with a high rise spoiler..
Nice color choice BTW.
It is done completely, I just don't have all the body parts mounted right now (side skirts, fender caps, front bumper). If you look close in the picture with the Supra you can see that it does have the 2gb sideskirts.
Thanks guys!
Car looks amazing man!! The exhaust work is insane as well! Whos doing all the fabbing/welding?
All the fab work is being done by JBDR, as he did all the fab work on my brother's MKIV Supra and it was phenomenal. I'm hoping soon to have pictures of my valve cover and catch can that he's done. I had the VC milled flat with vent line bungs and a new bunged oil cap welded on.
Wow its looking awesome, and you were right - whoever is doing the work on the exhaust and intercooler piping is doing a phenomenal job. What are you planning on using to tune?
Thanks! For now I've got a 98 flashable ecu that I'll be running CeddyMods bigmaps with speed density on. Depending on if I run into any issues with it, I might upgrade to a full standalone like AEM EMS next year.
Car is gorgeous man! I have two questions though, what kind of radiator are you using, and what kind of muffler is that?
Thanks! I'm running an upgraded radiator for a MK3 VW Golf and it fits inside of the rad support with some custom mounts. The muffler is a magnaflow oval canister with 3" in/out, don't have the exact part number on hand.
Some low-quality go pro pictures, but pictures nonetheless! Talon is done at the fab shop, just needs some small final assembly (fuel lines, turbo lines, misc wiring) then it'll be time for it's first fire up in almost 4 years!
I keep comin back to look at the car. LOVE the build and the car itself. Probably the cleanest 2g builds iv seen in a LONG time. You sir, have a sick car on ## hands. Please go with AEM or at the least dsmlink. To much quality in here not to. :hellyeah:
Some pictures to tide everyone over! The valve cover and catch can are out for powdercoating
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
