maximum9898
- 292
- 33
- Feb 24, 2008
Macomb,
Michigan
Well I've had this posted on dsmtalk for a while now, I just figured I'd share the beginning to end with tuners as-well. Now I might miss some of the pictures and details. But I'll post up a link to the other thread at the end of this. I'm not completely done with it yet. Have some tuning to do and misc. suspension. But other than that it is 98% done. It will probably never be "done" but it is very close to driving.
This is what it looked like when I had first started this build. It was very faded, had lots and lots of rock chips, and to many little dings to count. And a blown motor
Anyway all of this really started when I had blown my stock motor with 170k on it. A few friends and I didn't really know why it blew at first. But after looking through logs through ecmlink. It was determined that my CAS sensor failed at roughly 6000rpm at 30psi on a holset he351ve variable geometry turbo. And with this it had knocked and bent a rod fairly bad, the worst I've seen on a blown motor. And that's pretty much where this begins.
Here's the before/after of the motor when it was getting pulled. And at this time I still was unsure how bad the damage really was.
I had already blew the trans up a couple years ago. At that point I had sent it to shep and the diagnosis was the center diff exploded and wrecked a-lot of the trans. So I had them do the stage 3 and added a couple extra things as-well. So I guess what I would call it a stage 3.5. We'll that ended up blowing through the case 5,000 miles after. So called shep and they worked very professionally with me and rebuilt it for the cost of parts.
After I had taken the motor out I looked at the sub-frame and knew that it had to come and get cleaned up. And I always wanted to get rid of abs and I had finally ripped that out here as-well. Once all of that was pulled and I took a good look under-neath the car. I decided everything had to come down the rear sub-frame, gas tank, exhaust, abs, ect. The car was in a little bit worst shape than I thought it was.
And now here are all of the after pictures, Everything was painted gloss black and then cleared with automotive clear I had laying around.
I also had done just a little bit of polishing on the back of the diff cover.
