98 GSX DD with a Kick
Purchased as a shell and trying to bring it back to life.
efrainz28
169
15
May 27, 2008
Long Beach, California
Hello every one,
Intro:
I started to build a 96 GST with the newbie mentality. I wanted +800 HP and run high 8's as a daily driver. I see my post in 08 and I am ashamed. I still want to meet the +800 HP but I know I can't DD the car. I removed the A/C and summers are hot. I have to wear a tie (work) and I can't show up to a meeting all sweaty. :notgood:The windows get foggy and I can't see. The list of cons goes on... So, I decided to purchase another eclipse as a DD. I started to look around for a couple of months. I came close to buying a couple of cars but deals fail through. I found a 98 5 Speed GSX at a higher price for a Shell. I admit I paid too much for the cars. The car is in great shape and clean history. It has black dash is a plus for me. It does have a lot of miles on the car 180K. It came with Tein SS coil overs, HKS 272/272, and a 95 EPROM ECU. The seller used his AAA to have the car towed to my house.(75 miles one way trip) Over all I'm happy about my purchase.:D
Goal for the car:
I want to be able to DD the car comfortably and retain the A/C system. I will re-upholstery the interior with black leather.(EVO MR Recaro front seats) I want to repaint the car white again. I would like to have a nice looking car and reliable. I want 450HP to 500HP on E85 from a 2.3L 6bolt motor with 2G head. (350HP is more realistic) I plan to use ECMLINK V3 Full with SD.
Updates:Car Specifications:
Engine Internal:
  • [X]7Bolt 2G Cylinder Head Street port and polish, Crower Valve Spring w/ Titanium Retainer, Supertech Black Nitride +1mm Valve Intake/Exhaust, Supertech Bronze Valve Guides Intake/Exhaust, Supertech Valve Seal, HKS 272/272 Cams. Head Rebuilt by Millennium Motorsports Racing(all parts purchased just need to send it out to be rebuilt)
  • [X]2.3L 4g63T Block, Eagle Forged Connecting Rods, Wiseco Forged Pistons .20 Overbored (8.8:1 CR), 100mm G4CS Polished Crank, ACL Race Series Main and Rod Bearings. Built by MAP (Stage 1)
Fuel System:
  • [X]Wally 255 Fuel Pump
  • [X]-6AN Fuel Lines Feed/Return
  • [X]Magnus Fuel Rail
  • []Aeromotive AFPR
  • [X]FIC 2150CC INJECTORS with Delete Plug
  • []Fuel Lab 818
Engine Management:
  • [X]2G EPROM
  • []ECMLINK V3 w/SD
  • [X]AEM 3BAR MAP Sensor
  • []GM AIT Sensor
Forced Induction System:
  • [X] Evo 3 Intake Manifold
  • [X] 1G N/T Throttle body
  • [X] ETS 10.5" Race Intercooler Kit 4"Core Anodized Black.
  • [X] Tial Q BOV w/ 11 psi spring
  • [X] Punishment Racing T3 Turbo Manifold W/ 44mm Wastegate Flange
  • [X] Tial MVR 44mm Wastegate w/ 1.1 Bar Spring
  • [X]BEP T3 .70AR
  • [X]Holset HX-40 7 Blade Billet
  • [X]3" V-Band O2 Housing(Punishment-Racing)
  • [X]3" V-Band Down Pipe(Punishment-Racing)
Drivetrain:
  • [X]SHEP Stage 4 Transmission w/ Evo 3 First/Fifth Gear and Input Shaft
  • [X]Front quaife LSD.
Suspension/Handling:
  • [X]Tien Super Street Coilovers
  • [X]Brembo Calipers W/ JDM Knuckles,
  • [X]Goodridge Stainless Steel brake lines.
Pictures of the car:
Northstar White. My only weakness.. Sounds like a good build, man.
A 2.3 stroker on e85, you will find that 350whp will probably be easier than you think. cams, smim, and i'm not sure what turbo is on that , bolt on , but has a nice large downfiring compressor cover with what appears to be 4" inlet. probably something pretty nasty. However i dont see an AFPR which probably means he is on a stock fuel pump or a 190, seeing as its highly recommended to get an afpr with a 255+ as it may sometimes overrun your stock fpr.
I really like the car! goodluck!
PS, turbo kind of looks like some sort of holset w/ a bolt on housing. And is internally gated.
It became my weakness too. It was more of an impulse buy. I made the purchase with picture only.(Deal was made over the phone/picture but Cash transferred when I physically inspected the car and made sure it was clean.:cool:) When I see the car in person; The color said by me and take me home. Thanks for the kind words.:thumb:
Very good looking GSX man! Good luck with the build!
Your keeping me motivated!:thumb:Thanks
Looks awesome man! What turbo are you planning on running? What turbo is currently on it? What kind of fmic and intake mani are on it?
Thanks,:D For the turbo I don't really know yet. The car originally had a HX35 w/BEP .55 A/R Bolt on with VRSF Intercooler kit.(I didn't purchase it) The car was purchased as a shell. No engine and transmission. I did buy some parts but not all. I will be using ETS 10.5" Race Intercooler Kit 4"Core anodized black with a EVO3 manifold.
It had a Holset HX35 w/bolt on. The car currently has 255 in the tank. I will get a FPR eventually. The car was purchased as a shell and I want it that way. It gives me a fresh start to build it the way I want it. I know what's in the car and where it came from. Thanks:thumb:
I'm currently working on shaving the engine bay/ wire tuck. I'm thinking of painting the engine bay black.:hmm: If any one wondering what I'm working on. Trying to follow the Build Journal rules.(No several small updates spread across several small posts in the thread.)
I want lower the temperature under the hood. I had the manifold and other hot parts ceramic coated. I sent all parts to TCC and the part look good. The downpipe did not get ceramic coated because it would cost more than the cost of the downpipe. I will wrap the downpipe to help lower the temperature.
Before:
After:
Down Pipe
Some Pictures of the HX-40
The calipers are from an Evo8. I will powder coated to match the car.:D Powder coated white w/ black logo.
After I removed the paint with aircraft stripper.
ss brake lines
The calipers are currently with TCC to be coated. So , I have to wait.
The intercooler pipes are powder coated glossy black and the FP intake was a -10A/N fitting welded. The pipes where completed but I am still waiting for caliper/valve cover finished. I order injector from import evolution group buy. The injector should be delivered today. I haven’t been able to work on the car due to work load being high. I am currently trying to same money for a air compressor. I want a Quincy 5hp 2 stage 60 gallon 230 volt but with a price tag of $1,399.99 it might take a while. I might cheap out and buy a IR 5hp single stage for $900. I wont use it often but am concerned about the quality of the IR.
Wow, and I thought I had a lot of fuel with 3250cc/cylinder and 4 fuel pumps!
Are you still only running an HX-40? Are you running methanol? Are you intending on going to a mechanical fuel pump or cable fuel pump setup?
Just asking as I looked through the last 25 posts or so and only saw the Walbro 255 intank and HX-40 setup.
Tim Zimmer via Evo Phone
wow that's a nice car, loving the 2G's more and more! Keep the updates coming.
Thanks, Ill try to update weekly.
Looks like a nice build.
Thank you for noticing. I'm putting a lot of time and money into this project. I research a lot and it's slowing the progress. It should be a solid car when I am done.
Great looking car man, i also bought a white 2g without any inspection LOL.
Northstar white is just too sexy to not buy.
Will be following your log, good luck!
I put a down payment just looking at picture. I feel in love with it in person.
The car was making 350whp on stock rebuilt 2.0l before it was parted out.. I know the ex owner. Clean car, Nice build!.
I bought the car from Medrivfast.He is a very nice guy. Communicated well and worked with me. I had to fly to Texas to work and he held the car until I returned. He let me use there AAA and tow the car to my house.(75 miles) His wife is funny.
Looks great, you can never go wrong with a white 2gb
Very true
two full sets of 2150s?!?!
Yes, I am building two cars.
I will use the HX40 but am thinking of switching to FP green. IF the HX40 is too lagy on the street it will be replaced with a FP Green. E85 for fuel and Single rewired wally or Bosch 044
dam 8x2150 thats alot of fuel for a twin turbo big block....
I have a LS1 camaro I will turbo or supercharge later. I might use this if there compatible.
awesome looking build. love the hx40 makes my 16g look like a t25 LOL
Size matter LOL
He bought the shell from me. I'm just glad it went to a good home. Last time I drove the GSX was coming home from MOD. I do miss her. It had an HX35 8 Blade pushing 20lbs. According to DSM Link I was flowing 47lbs/min on pump gas. I did replace her with an 01 Corvette Z06.
I will take good care of the car.:thumb: It's in good hands.:cool:
Looks like a nice build. Why did you decide to get a 2.0 6 bolt block machined for the bigger crank instead of using a G4CS block?
Thanks, Like most people with a 2.3L; I already had a 2.0L block just needed the 100mm crank. I am looking for a 2.4L for my other car but I'm having difficulty finding one.
  • For sale 2g 2G DSM Link V3
    • frosh29
    • The_Partout_Spot
    • The_Partout_Spot
