do 92 GSX's with ABS have limited slip rear end
obssesed
47
Jul 29, 2002
Hi I was wondering if 92 GSX's with limited slip rear end have limited slip rear ends and, could you install a limited slip rear end if it didnt have one. Would you install then a 4 bolt rear?
I have a 92 TSI AWD with 6 bolt motor, ABS, and yes i have an LSD, when you open your drivers side door, look on the right side (when climbing in) (on the inside of the frame, not on the door itself) there should be an orange sticker saying 'WARNING: THIS VEHICLE IS EQUIPED WITH A VISCOUS TYPE LIMITED SLIP DIFFERENTIAL' or something like that, thats what mine has.
