1fast97gsx
- 4,517
- 17
- Jul 6, 2003
Orland Park,
Illinois
As you may or may not have heard I had my trans rebuilt and the guy did a shitty job siliconing it so it was leaking out of the casing. He offered to fix it but said it would take a while because he'd be working on it "whenever he can get to it" ... so I decided to do it myself. I rebuilt my own motor and helped with others, but I've never took apart a trans. I didn't think it could be too difficult though.
Anyways, I got it all apart and all the cases seperated. I put it all back together in reverse order ( I think I did it right ) ... but it's VERY hard to move the gear selectors into 5th and reverse. Since 5th gear was the gear I totally pulled off maybe I did something wrong when putting it back on? And also when in neutral ... isn't the input shaft supposed to spin freely with fairly little force? I tried to spin it clockwise and I was turning pretty hard and it just wouldn't turn. Did I somehow lock up something inside the trans to cause this problem with 5th and Reverse and to keep it from spinning freely in neutral. Does anyone have a picture of all the parts and how they are assembled inside the trans so I can compare and double check everything? What should I look for that would cause these problems? Please help me I want to drive my car again!!!! Thanks.
